Wich version vMix for play out use?
Hello Everybody,
It's a very basic question but we can't figure it out. We want to use vMix for play-out graphics, lower thirds, video's etc. to our Atem switcher. Wich version do we need to purchase? The HD version so we can us the full screen output for the fill signal and the external output for the key? Or do we need the 4K version with multiple external outputs?
I hope to hear from you!
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
I hope to hear from you! I use vMix with ATEM You need decklink duo 2 black magic card which has option for fill and key and its working with vMix, connect cables to ATEM (input 7 and 8 for example) and go to downstream key and setup Fill and Key on that inputs. Or you can buy Intensity pro card and go over HDMI output on external and go in ATEM in input 1 (HDMI) and play with chroma or alpha My suggestion is decklink duo 2 because I use it too. You need at least HD version because of resolution and also total input limits. There is no need for Fullscreen only One External output to decklink duo 2 (Fill and key) and ATEM. Best regards
Thanks for your reply!
We've bought the Ultrastudio HD mini and that should be working according the vMix guides. I think in the same way you describe with the decklink cards.
So for the key and fill you use one output channel in vMix?
I already brought Ultrastudio HD mini and Decklink Duo2. but only Decklink Duo2 can output Fill & key SDI signal via vMix I cant use Ultrastudio HD mini to output any signal eventhought change all settings vMix unsupported HD mini output ?
So for the key and fill you use one output channel in vMix? Yes, set the card output to resolution you need, set your card at connector mapping to SDI1&SDI2, in vMix set the resolution you need, choose device, in Alpha Channel set Premultiplied. I alrady use that with reference also and it works perfect. I dont know for Ultrastudio HD mini but looking at guide it should work. If you need any help feel free to contact me on email live@hercegovinalive.comBest regards
Originally Posted by: Siroki  Originally Posted by: Mick_SSR  Thanks for your reply!
So for the key and fill you use one output channel in vMix? Yes, set the card output to resolution you need, set your card at connector mapping to SDI1&SDI2, in vMix set the resolution you need, choose device, in Alpha Channel set Premultiplied. I alrady use that with reference also and it works perfect. I dont know for Ultrastudio HD mini but looking at guide it should work. If you need any help feel free to contact me on email live@hercegovinalive.comBest regards Oh ,im stupid , i forgot start ext output when i using UltraStudio HD mini. it works now ,thanks a lot
