Feature Requests
Replay playback with audio from 'active' angle
You have been a member since:: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, Denmark Thanks: 422 times Was thanked: 102 time(s) in 79 post(s)
Hi vMix,
It is rare that audio is used when playing back audio in replays, but I have a case where it is relevant. We have 4 camera angles each with different audio which is desired to be used for instant replay. Each camera angle has audio in it, and it is desired that the camera for each of the cameras are used when outputting using the instant replay module.
This is currently not possible, since the options for audio playback in the instant replay module is currently audio from either: Master (output), Camera1, Camera2, Camera3 or Camera4. What is desired is then to have another option to be "Source", meaning that the audio is being taken from the active camera angle.
This should be a fairly simple feature to implement, is all the audio channels are already in the recordings, it is just a matter of bringing them into the playback.
Thanks!
/ Jens Stigaard
Feature Requests
