Hardware Compatibility
8 inputs on Microsoft Surface Pro in vMix possible ?
Joined: 12/3/2018(UTC) Posts: 57   Location: Vejle Thanks: 49 times Was thanked: 2 time(s) in 2 post(s)
Hi
Would it be possible to run 8 x 1080p25 inputs into a Microsoft Surface Pro 4 using vMix ?
If so, what interface would you recommend ?
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
If I had to give a Yes/No answer it would be NO. Seems under-powered and with no suitable ports for getting 8 video channels into it, apart from maybe low-bitrate H264 IP feeds, but then it might struggle to decode and do anything meaningful with them.
 1 user thanked zenvideo for this useful post.
I have the Pro 3, and while its not the same model, it can't really handle anything in vMix nicely, so I doubt theres a significant improvement in the 4 to allow what you're asking for. The only real improvement is the newer generation CPU's, which isn't enough to make that kind of a difference.
 1 user thanked spencerm24 for this useful post.
