wscawebcast
#1 Posted : Thursday, January 9, 2014 7:47:42 PM(UTC)
wscawebcast
1. Add Input, Animated Ticker HD3
2. Change text, text formatting, text color, and duration
3. Save ("+") settings as Title Editor preset
4. Save vMix Preset
5. Open vMix Preset
Right-click on Input shows text, but selecting it does not restore formatting, color, or duration. Entering Title Editor and selecting preset also does not restore formatting, color, or duration.
#2 Posted : Thursday, January 9, 2014 10:01:18 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
Text Editor settings will not be saved in the preset if it is running.
You will need to ensure it is paused and then save the preset.
wscawebcast
#3 Posted : Friday, January 17, 2014 9:26:35 PM(UTC)
wscawebcast
Pausing the preset and saving did work. But that also means that I have to "play" the input the next time I load the preset. Not the end of the world, but it would be nice if it could be auto-played on load.
DJDoubleC
#4 Posted : Sunday, January 19, 2014 10:09:13 AM(UTC)
DJDoubleC
Good morning, How do you speed up or slow down the speed of the scroll ticker?
#5 Posted : Sunday, January 19, 2014 10:24:04 AM(UTC)
The speed of the ticker is determined by two factors:
1. The duration of the ticker, this can be set by clicking the Clock icon in the Title Editor.
2. The length of text.
The two work together, so a ticker with 100 words set to 2 minutes will
run twice as fast as a 50 word ticker with the same duration.
