Ario
#1 Posted : Wednesday, November 28, 2018 7:24:00 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Dear all,
I managed to get my 15 (and via subfolders: unlimited) button Elgato Stream Deck to mostly do what I want,
which is mainly to fire off commands, quite often multi-actions, around previewing and switching cams,
and storing, playing back, and tweaking replay events.
I'm hereby sharing my profile:
https://www.dropbox.com/s/g9jwyhvlmg02sxr/VMIX_Elgato_profile-and-pngs.zip?dl=1
which includes the png images (and psd's) that I use,
which are simple color coded cut-outs.
The Stream Deck basically has 15 mini-lcd's, behind each of which you can show any image and/or text.
The input numbers are in my case input1 for my main/wide cam, input2 for my close-up, etc.
Of course in your case all this may be different, but this profile can still be of help.
Wait times for several multi-actions assume that an IRP-event has a duration of 5 seconds.
The only term not translated is 'Leiden', the home team's name for many of my basketball streams.
Actions are based on URL commands and based on localhost, so it assumes the Elgato and vMix run on the same PC.
If you run them separately, replace localhost with the IP address of the PC that vMix runs on.
And don't forget to enable the Web Controller in the vMix settings.
The big advantage of Web commands is that vMix does not need to have focus (be in front) on the PC, for the Elgato commands to still trigger actions in vMix.
Figuring out, how to use the Delay as an extra replay (I use it to replay e.g. personal fouls in the game, that I don't want/need in my IRP export .mpg and playlist) and especially how to let it transition, was a bit of an effort, so I'm quite proud of the resulting "QP Delay" (QuickPlay Delay) multi-action key for that.
My delay has a span of 7 seconds.
The levels go 3-deep, since from the main screen there are 3rd levels (irp and tweak) under the 2nd "RP" (replay) level.
This may well be impractical, but folders can be moved around easily in the Stream Deck editor.
Hoping that you find my profile useful and that it may be a building block for others' configurations,
wishing you all happy streaming,
looking forward to another FIBA gig on Thursday,
cheers,
Arie
Some small impressions:
2018-11-27 22_04_42-Window.png (21kb) downloaded 1 time(s). 2018-11-27 22_05_17-Window.png (22kb) downloaded 1 time(s).
thanks 3 users thanked Ario for this useful post.
avsoundguy on 11/28/2018(UTC), RiverBen on 11/28/2018(UTC), rowby on 1/6/2019(UTC)
Ario
#2 Posted : Sunday, January 6, 2019 9:52:26 AM(UTC)
Ario
Modified UPDATE (on Jan. 24, 2019):
the below works well for me, AS LONG AS in the IRP console window, IRP A is on angle 1, "Set Replay A to Camera 1" as the mouse-over tells you (green box is on 1, for row A, the row with P-1-2-3).
The setting of IRP B is inconsequential for the routine, it will work alright at both 1, 2, and 3 angles.
(earlier, I thought moving events to a different bank threw the routine off, but that seems perfectly allowed)
Okay, here is the original post:
(Download link to Elgato profile below)
Wanted to give an update, it explains how to deal with easy marking and playing back of replays when using multiple angles, when the action is visible on the main camera always, and on one of 2 other cameras,
them being slamcams in a basket. The action is under one of the two baskets at a time.
The three cameras are picked in the replay recording setup (requires vMix Pro).
The first button is for:
Marking a 5 sec. replay,
putting it in Bank 2 with cam 1 (wide) toggled on,
and in Bank 5 with cam 1 (wide) AND cam 2 (slamcam in basket X) on,
and in Bank 7 with cam 2 (slamcam) on
... all with one keypress on the Elgato.
I work from Bank 2. After a time-out/break is over, I move all replay events from Bank 2 to Bank 1. So in the end, Bank 1 has all the events, and Bank 2 has only the ones since the previous break.
How?
Make a multi action "-5 Team A" and put these actions in it, with a Delay of 5 ms after each action (longer delays are indicated below, if any):
Activate Bank 2
http://localhost:8088/API/?Function=ReplaySelectEvents2
Make a 5 sec. IRP in bank 2 (cam 1 is on by default)
http://localhost:8088/API/?Function=ReplayMarkInOutLive&Value=5
cam 2 toggle ON in bank 2 (gets toggled back off later)
http://localhost:8088/API/?Function=ReplayToggleLastEventCamera2
copy to bank 5, cams 1 AND 2
http://localhost:8088/API/?Function=ReplayCopyLastEvent&Value=4
cam 1 toggle off in bank 2 (cam 2 remains toggled on in bank 2), this gets reversed later
http://localhost:8088/API/?Function=ReplayToggleLastEventCamera1
copy (cam 2 replay angle) to bank 7
http://localhost:8088/API/?Function=ReplayCopyLastEvent&Value=6
cam 1 toggle back on (in bank 2)
cam 2 toggle back off (in bank 2)
Do the same for the slamcam in the other basket ("-5 Team B"), except replace replay cam2 with cam3, cam3 being your slamcam in the other basket and having position 3 in the Replay console of vMix.
This will be your second button.
Make a clone of the Elgato template (profile) and swap team names A/B in the clone, so you have a template for the 1st half, and one for the 2nd half, when teams have switched sides.
Third button:
Elgato button to play back the replay event from 1 angle:
REPLAY LAST event, Main cam only (a 5 sec. replay)
Activate Bank 2 (Main cam angle)
Replay Last Event
http://localhost:8088/API/?Function=ReplayPlayLastEventToOutput
Delay
1000 ms
Delay
5500 ms
Put Input 1 (which has my Main cam) in Pvw, after the replay it will be switched to Pgm Out
http://localhost:8088/API/?Function=PreviewInput&Input=1
Put Close cam (input 2 in my case) in Pvw
http://localhost:8088/API/?Function=PreviewInput&Input=2
Fourth button:
Elgato button to play back the replay event from 2 angles:
REPLAY LAST event, BOTH cams, so 2 angles (a 5+5 sec. replay)
Activate Bank 5 (Both angles)
http://localhost:8088/API/?Function=ReplaySelectEvents5
Replay Last event (which in Bank 5 already has 2 angles toggled on)
Delay 2000 ms
Delay 11000 ms
Activate Bank 2 (Main angle), just to make double sure a new replay event mark lands in that bank first
Download Elgato StreamDeck template:
https://www.dropbox.com/...s.streamDeckProfile?dl=1
The described 4 buttons are named
-5 Lei (Team A)
-5 Kata (Team B)
RP Last
Both Last
... all on the first page of the template (see more stuff behind the 'Subs' button in the template).
thanks 1 user thanked Ario for this useful post.
Quinton on 3/3/2019(UTC)
