HTTP WEB API (REST API) recording
good evening, I need the syntax to send a command thhp web api to start recording with file name and specific path how can I do? thank you regards Ettore
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
You can only send a command to start/stop the recording , it doesn't include the path/name location parameter which you have to specify in the recording configuration
pity .... I need to change the file name of the registration via http api
are not there any updates in this direction either? otherwise I will have to organize myself in another way thank you
Originally Posted by: mixsystem  organize myself in another way
is what we did ;-)
