ELCtec
#1 Posted : Friday, November 23, 2018 2:39:46 AM(UTC)
ELCtec
Germany
we are trying to integrate our production into the web controller. We would like to use the web controller the same way, we are using our Xkeyspad.
We are using some simple macros on our Xkeys, which looks like:
Button one:
Mute Source 1
Mute Source 2
Mute Source 3
Unmute Source 4
Insert Input to Preview
Stinger to live
Button two:
Mute Source 1
Mute Source 2
Unmute Source 3
Mute Source 4
Stinger to live
and so on...
We are facing the problem that we cant integrate this in the web controller on one button, as long we are not using a script, which you can map to one.
I got it working, without any VB.net knowledge, that the input is loaded and switches with a stinger to the live output.
Input.Find("INPUTNAME").Function("PreviewInput")
Input.Preview.Function("Stinger1")
I tried to add lines for mute and unmute the sound of the four inputs, but they are not taking it.
Input.Find("INPUT1").Function("AudioOFF")
Input.Find("INPUT2").Function("AudioOFF")
Input.Find("INPUT3").Function("AudioOFF")
Input.Find("INPUT4").Function("AudioON")
Also tried it with 1/0
Input.Find("INPUT1").Function("Audio=0")
I know that you can use the commands from shortcut function reference, but not how to insert them right
We think this is quite easy for someone with a bit more insight.
Willi
#2 Posted : Friday, November 23, 2018 4:15:05 AM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Why don't you use Web Scripting ? It's much easier if you don't have VB.Net knowledge...
https://www.vmix.com/help21/WebScripting.html
Guillaume
ELCtec
#3 Posted : Monday, November 26, 2018 11:43:31 PM(UTC)
ELCtec
Germany
I will work through it. Going to report here if it worked out.
