I can't figure out what trigger calls to make/where to set them to do the following:
Input 1: Countdown timer (1 minute) Input 2: Video (60 seconds) Input 3: camera Input 4: multiview with Input 3 camera and Input 1 countdown timer
1. Show the multiview with Input 3 and Input 1 countdown 2. when the countdown ends play the video in Input 2 3. when the video ends, transition back to Input 3
I've tried various combinations and right now the active screen gets stuck at the end of the video and doesn't transition out to anything.
@ spock
This is how I would set it up:
a) Trigger on Input 1: OnCountdownCompleted / Fade / Input 2
b) Trigger on Input 2: OnCompletion / Fade / Input 3
