iamralphsutton
#1 Posted : Wednesday, November 7, 2018 4:08:46 AM(UTC)
iamralphsutton
Looking to resolve both of these issues.
How to get a call screening situation for multiple voip lines.
and how to get some sort of auto-ducking plugin for vmix.
any suggestions?
mavik
#2 Posted : Tuesday, November 13, 2018 10:27:59 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Vmix call has a mix minus integrated. You can work with triggers to duck audio.
I would to all the audio stuff external. If you have a lot of sources a propper mixer will take off the load. I use a Behringer XR 18 that has a automix function and ducking build in.
mjgraves
#3 Posted : Wednesday, November 14, 2018 1:19:31 AM(UTC)
mjgraves
Call screening for voip lines will be external to vmix. You have two options;
1 - Use a hosted PBX service that allows you take calls into a receptionist or queue, put them on hold (or park them) then transfer them to the "studio" extension.
2 - Use a robust conference service. Some have similar capabilities. I use ZipDX, which has breakout rooms and the ability to move callers between rooms. You can receive the calls into a waiting room, move them to a green room, chat them up, eventually xfering to the studio.
Similar results, different approaches to the mechanics. Neither will be free, but they need not be costly.
Guest (4)
