Slaver
#1 Posted : Monday, October 22, 2018 10:04:50 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Hello, hope you guys can help me out with my problem.
I have the problem since the last 3 month, that when i click on "Fullscreen" to activate the 2nd Monitor, the render time goes over 31 ms. GPU overload is appearing.
I am using a i7-5820k, 16GB Memory and 1060 Geforce. The Setup is really small. Just 2 SDI-Cams, 1 Replay-Channel, 2 Videos and 1 Watermark.
All the latest Updates were made.
Thank you for help!!
liveteko
#2 Posted : Monday, October 22, 2018 10:43:49 PM(UTC)
liveteko
Sweden
See if this helps:
1) Try to run the vMix Diagnostics and see if any issues are detected
2) Update your graphics driver
3) Follow these tips: https://www.vmix.com/kno...2/optimising-performance
Slaver
#3 Posted : Tuesday, November 20, 2018 1:30:06 AM(UTC)
Slaver
Thank you @liveteko
I did everything what you wrote but nothing changed.
The GPU Overload appears even when i am not streaming or recording anything. Just open a new preset. 2 cams, 1 channel replay, 2 Videos and a watermark and i am above 30 ms render time.
vMix Diagnostic says no other programs are using the graphics card. All the other help instructions from the vMix Website are also without any changes.
Is there anything else i can do?
