video delay output upside down
Joined: 3/7/2012(UTC) Posts: 503 Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
Hi Martin,
playing around with the video delay and noticed two points:
1 using my webcam c920 as an input the recorded delay clip is upside down.
2 recording in mjpeg the recorded file has a bitrate of 50 mb/ sec... can this be adjusted?
i have now installed the cineform codec which i can set to low hd. may this way i can finetune the delay clip. If i can lower the quality the saving will be faster i presume. the size i can not change when using an input.
greetings, stefan
