Feature Requests
Title settings window resize
Joined: 7/8/2016(UTC) Posts: 53   Location: Ukraine Thanks: 13 times Was thanked: 5 time(s) in 3 post(s)
Hi! It is often needs to save many names at title preset, and it will be great that it will be possible to resize window inside, to change ratio of main field and field with saved list  title.PNG (24kb) downloaded 0 time(s).
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
If you have a large number of entries, it's much better to use either the WebController or the CSV import feature or even the datasource option.
Changing the UI is not a solution, it will never fit every possible situations
Guillaume
Nope. It's veru usefull as it, but option to resize will be great. It needed only when you addin new entries, but often you may duplicate entry or somethig else, so to check what you do it will be great.
That's why I advised you to use the CSV import feature. It's even more convenient and efficient, much faster and by using a good text editor like EditPad or equivalent, you even get powerful search and replace options. Just try, you will see...
After adding 1 or 2 entries, just use the export function, then open the resulting CSV file with a text editor (notepad will work but not the best), then add 100 or 2000 entries if you like and finally just import the CSV. Nothing in changing vMix UI can beat the ease of working directly in full screen in a decent text editor.
Feature Requests
