ceejay7777
#1 Posted : Monday, December 9, 2013 6:03:10 AM(UTC)
ceejay7777
A bloke in Sydney has just done some work on adding the guts of an ATEM software switcher to the back-end of an old Grass Valley 110 (https://www.youtube.com/watch?v=s5BvDxLWtog).
Given that vMix can be controlled by keyboard shortcuts, is it a big stretch to go down the path of something similar? For my part, I have an old Sony SEG-2550 and it would be bloody marvelous to see it control vMix!
Henny
#2 Posted : Monday, December 9, 2013 7:27:14 PM(UTC)
Henny
playing with same idea , but with a datavideo rmc-90 - which is an rs232 remote for a datavideo mixer uesing a arduino to link to the Vmix API
Henny
#3 Posted : Monday, December 30, 2013 8:26:59 PM(UTC)
Henny
Had a play tonight with getting an arduino to control V-mix, a copy of the sketch can be found below, bit crewd for now but just a proof of concept. Buttons 1,2 & 3 select an input to the preview and the 4 button cut's it to program . Also added an LED to confirm that it has connected to vmix
cheers
Ian
Code:
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(192,168,0,6);  // numeric IP for Google (no DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192,168,0,177);
// pin button:
const int button2Pin = 2;     // the number of the pushbutton pin
const int button3Pin = 3;
const int button4Pin = 4;
const int button5Pin = 5;
// variables will change:
int button2State = 0;
int button2StateOld = 0; // variable for reading the pushbutton status
int button3State = 0;
int button3StateOld = 0; // variable for reading the pushbutton status
int button4State = 0;
int button4StateOld = 0; // variable for reading the pushbutton status
int button5State = 0;
int button5StateOld = 0; // variable for reading the pushbutton status
int led = 9;
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
void setup() {
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
  // initialize the pushbutton pin as an input:
  pinMode(button2Pin, INPUT);
  pinMode(button3Pin, INPUT);
  pinMode(button4Pin, INPUT);
  pinMode(button5Pin, INPUT);
   pinMode(led, OUTPUT);
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  delay(1000);
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    digitalWrite(led, HIGH);
  else {
    // kf you didn't get a connection to the server:
    Serial.println("connection failed");
void loop ()
  loop1 ();
  loop2 ();
  loop3 ();
  loop4 ();
void loop1 ()
  button2StateOld=button2State;
  button2State = digitalRead(button2Pin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (button2State != button2StateOld)  {
    if (button2State == HIGH){
      Serial.println("Button1");
      client.connect(server, 80);
      client.println("POST /API/?Function=PreviewInput&Input=1");
      client.println();
      client.stop();
void loop2 ()
  button3StateOld=button3State;
  button3State = digitalRead(button3Pin);
  if (button3State != button3StateOld)  {
    if (button3State == HIGH){
      Serial.println("Button2");
      client.println("POST /API/?Function=PreviewInput&Input=2");
      client.println();
      client.stop();
void loop3 ()
  button4StateOld=button4State;
  button4State = digitalRead(button4Pin);
  if (button4State != button4StateOld)  {
    if (button4State == HIGH){
      Serial.println("Button3");
      client.println("POST /API/?Function=PreviewInput&Input=3");
      client.println();
      client.stop();
void loop4 ()
  button5StateOld=button5State;
  button5State = digitalRead(button5Pin);
  if (button5State != button5StateOld)  {
    if (button5State == HIGH){
      Serial.println("Button4");
      client.println("POST /API/?Function=cut");
      client.println();
      client.stop();
thanks 3 users thanked Henny for this useful post.
jet on 1/2/2014(UTC), smudge1977 on 11/30/2014(UTC), nuvi_cakep on 3/15/2016(UTC)
RVtv Video
#4 Posted : Friday, October 24, 2014 9:52:10 AM(UTC)
RVtv Video
Thanks Henny,
I am building my controller with your sketch and also made a fader control will post the pics soon.
Greetz Richie
thanks 1 user thanked RVtv Video for this useful post.
nuvi_cakep on 3/12/2016(UTC)
Bardos
#5 Posted : Friday, October 24, 2014 11:52:26 AM(UTC)
Bardos
Groups: Guests
Guys, your ideas are great...I keep asking if there is anyone that can build a software only version, much like VJDirector, AVTake, or any that use such features......
I was working with a Livestream Studio setup over the weekend, and I really enjoyed the layout....If I am not using an audio mixer, why have it there taking up room on the desktop, same for other items....I like the way I can free up space with their tab system.. If I need to select a clip, I just click the 'Media' Tab, and all my clips show up...I need transitions, I do the same.....and so on....I wish that vMix programmers would think about creating a similar style, as it frees up the desktop, and will leave room for a switcher, which does not have to be too sophisticated, just simple like in VJDirector, or AVTake, where the selected bus and input glows Red or Green, depending on colour scheme chosen in vMix...yes, I have worked with VJDirector some years ago, but it has great limitations, but it worked great....It is also the only program I worked with that has the 'Program' Window on the left, and the 'Preview on the right.....kind of odd, but that is the designers' choice.
I also, out of curiosity, downloaded and tested Livestream Studio, and found the design rather attractive, and comfortable to work with......I am NOT condemning vMix, just that I like the GUI that some other programs have...They are more like the real thing, so just sitting in front of them, needs little to remember, as they are set up to mimick a hardware switcher....As I have said in other posts, all vMix needs now is a switcher....... just my thoughts......
Someone was building an hardware switcher for vMix, but I have not seen much more about it here...http://forums.vmix.com.au/default.aspx?g=posts&t=2568
Bardos attached the following image(s):
Control Panel.jpg (67kb) downloaded 20 time(s).
thecloudmediagroup
#6 Posted : Monday, November 17, 2014 12:03:42 AM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
Correct! We are still in development of the hardware control surface for vMix! We are getting very close to releasing additional details and photos for the surface.
Similar Topics
vMix and TriCaster hardware control panel (Hardware Compatibility)
by kip 10/9/2018 8:54:12 PM(UTC)
Custom SKAARHOJ Hardware Control Panels (3rd Party Software and Development)
by mashynewie2 3/24/2016 6:20:54 AM(UTC)
