start a stream and run a video at a specific time
Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
I know there are a few 3rd party schedulers...
Is there one that is preferred and that can do this?
We have a lot of shows that pre-tape. and instead of having to have someone just sit there waiting to push play. It would be great if we could have all the pre-taped shows for the week loaded on a separte machine that automatically starts and stops the live streams of the shows that are pre-taped.
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
We currently use vTask and vMix to run a tv channel. vTask has been great with the one exception that when running in API mode it doesn't always remove the inputs after playing the video (ie. it's supposed to add and play a video at a scheduled time and remove it when it's done). This can lead to issues if you're not removing inputs on a regular basis.
