Crawl Stutter and showing fields
Hi there, We are using an standard crawl template which comes from the Vmix pre-installed software. But when going live on facebook, the crawl stutters and also it seems like it is being played with fields. Our output is 1920P25, so it has to be all progressive (See attachtement [img]https://ibb.co/enJcTe[/img]) Also I noticed that output framerate is flucturating. Is this normal? [img]https://ibb.co/n1NXuK[/img] our specs Windows 7 8gb RAM Intel Core i7 3.6 Ghz Nvidia Gefroce GTX 1060 6GB dijklarg attached the following image(s):  Fields in Crawl.jpg (137kb) downloaded 9 time(s). framerate.jpg (36kb) downloaded 9 time(s).You cannot view/download attachments. Try to login or register.
Joined: 1/13/2010(UTC) Posts: 5,350  Location: Gold Coast, Australia Was thanked: 4759 time(s) in 1633 post(s)
Hi, Go to Settings -> About and click Send Support Report and email us at info@vmix.com.au the registration key. We should be able to quickly see what is going on. If vMix is set to 1080p25 (it is not streaming in that screenshot) then it will definitely be a progressive ticker. vMix only creates an interlaced ticker if set to 1080i50 somewhere. Regards, Martin vMix
