Joined: 10/2/2018(UTC) Posts: 3 Location: United States
When running install I get Netframe 3.5 error. I installed 3.5 and got a message I didnt need it as 4.0 is installed but all of them show up in system. I am installing it on an ASUS G752. has anyone else had this issue?
Joined: 8/11/2018(UTC) Posts: 60   Thanks: 33 times Was thanked: 6 time(s) in 6 post(s)
which OS are you using? For Windows 10 it should be enabled as feature if not active.
Im not that smart on computers, where do you enable it? Thanks for your help
Windows 10. Turn windows on or off box is blank
