#1 Posted : Wednesday, September 26, 2018 9:05:46 AM(UTC)
The AES67 to NDI Gateway includes an SAP listener function to automatically detect any multicast AES67 sources on the network, and automatically publish an NDI version of each source.
The NDI Sources are visible to all NDI applications on your local area network, but no processing takes place until one or more NDI applications connect to the NDI source, at which point the AES67 to NDI engine starts up a low latency, transparent translator between the AES67 source and the new NDI stream.
When all NDI applications release the source, AES67 to NDI will once again hibernate that source, keeping it offered to all NDI users, but consuming no processing load.
This seamless mechanism provides one-click, instant connectivity between your AES67 audio devices and your NDI Devices.
The AES67 to NDI Gateway will form a key component in the NDI Processing engine for the NDI Smart Processing Router product and is also available as a stand alone product (for macOS, Ubuntu and Windows).
** Note by DWAM:
- I have not tested it yet but this should work fine with DanteAES67 (not all Dante feeds)
- Ravenna is also offering a gateway for AES67 based on Bonjour and mDNS protocols to make them work with SAP discovery, it's called RAV2SAP
Very interesting solution I believe
Guillaume
