Joined: 12/1/2013(UTC) Posts: 56   Location: Ellenboro Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Does anyone know if vMix v21 and Windows 10 support the Roland VR-3 switcher? I am planning to buy a used one to run 4 older composite PTZ cameras. Currently running 2 cams with capture devices but would like to eliminate them while increasing the number of cameras at the same time.
vMix 20 does. Try these settings:
Resolution: 720 x 480 (29.97fps/Motion-JPEG) Audio: 48kHz/16bit
I can report that vMix 21 recognizes the Roland VR-3, both audio and video. No driver needed.
