One Datasource - Different Row for different Titles
Is it possible to map different Rows of a Data Source to different XAML Titles?
For example: I have a XML File with the Last 3 Results of a Sports Event, these 3 Results change all the Time during the Event.
In the Data Source i create a new XML-Source which shows all of the Results in 3 Rows.
In vMix i have 3 different "Title Xaml Inputs" on different parts of the Screen.
I choose the first one and connect it to the Data Source - Data of row 1 is displayed - so far so good. I choose the second one, connect it to Datasource, change it to the second Row. - The first and the Second Title now Display Row 2 I choose the third one, connect it to Datasource, change it to the third Row. - The first, second and third Title now Display Row 3
Am i doing something wrong or do i really have to add 3 different Data Sources with the same XML File just to display different rows with different inputs?
Thank you in advance.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
You can not mix and match rows/columns. Behavior you are describing is by design like this.
You should convert rows to cloumns. That way you will have one data source row and can connect specific column to the title.
Thank you very much! That works for me.
