vMix Call
vMix Call connection resolution not as selected
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 203 time(s) in 169 post(s)
Using version 21.0.0.55 this morning and connecting to a vMix Call from a remote host. I select High 1080p 4000kbps but when I check Call Manager the actual resolution is 720p and bit rate is roughly 1200.
The rt click menu shows I have selected 1080p but Call Manager shows 720p.
I have tried Reconnect, no difference I have tried closing that input and adding a new Video Call input, no difference.
Any ideas?
- Tom
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
Hi Tom,
Remember that the resolution selected on the vMix right click menu is for what the caller receives on their end. The resolution/bandwidth of what you receive (and see in the stats) in turn is determined by the caller.
If they are using a browser, it is auto-adaptive up to 720p 2Mbps based on network conditions. If it is vMix on the other end as well, it is determined by their right click menu setting.
Martin vMix
So I'm a dummy, again. My bad. Lol. I'm deleting this post! Agh!
Thanks, Martin!
- Tom
vMix Call
