adimw
#1 Posted : 7 years ago
adimw
Hi all
I've got an issue with vMix whereby the Zoom UAC-8 will work in vMix for about 5 minutes and then drop off (no audio coming into vMix)
I've checked windows sound settings and disallowed 'exclusive control' and also tried disabling the device altogether, the issue remains the same
Did anyone run into ASIO issues with Win10 LTSB and switch to CBB?
Here is my computer build:
https://forums.vmix.com/...aspx?g=posts&t=16290
SportsNetUSA.net
#2 Posted : 7 years ago
SportsNetUSA.net
Do you get the same error message if you set the Zoom UAC-8 as the Default audio device?
adimw
#3 Posted : 7 years ago
adimw
Good idea, as per your suggestion; I've set all defaults (default and defaults communications) for both playback and mic to the Zoom.
It lasted in vMix about 1 minute before the inputs dropped off again.
Failed state - no input audio at all.
If I restart vMix this is it working (at-least initially)
SportsNetUSA.net
#4 Posted : 7 years ago
SportsNetUSA.net
Have you tried the ASIO4ALL driver?
http://www.asio4all.org/
thanks 1 user thanked SportsNetUSA.net for this useful post.
adimw on 8/31/2018(UTC)
kgoodyer
#5 Posted : 7 years ago
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
I agree, I use a Zoom-R16 and had so many issues until I went for ASIO4ALL. This also looks pretty classic of the Zoom Drivers if the USB link goes down. This could be caused by the USB link itself going into a power saving state. Probably worth checking.
thanks 1 user thanked kgoodyer for this useful post.
adimw
#6 Posted : 7 years ago
adimw
thanks both, have just checked power settings and USB power management was on. will test again and see if this is the culprit.
next up will be trying ASIO4ALL and if thats a no go, I think I'll move to CBB from LTSB
adimw
#7 Posted : 7 years ago
adimw
Crazy as it seems, the USB power management seems to have been the culprit!
thankyou all for your input :)
goaliebob99
#8 Posted : 5 years ago
goaliebob99
I'm having this same issue with a Zoom L-8. Power management doesnt seem to work. I cant seem to get the zoom to work with ASIO 4 all either. :( Any suggestions?
