Joined: 7/14/2017(UTC) Posts: 100   Location: South Florida Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Is there a way to shut down a stream automatically. When I replay shows, I have to set an alarm clock to go back into the studio and shut down the stream. Is there a way to automate this process?
Joined: 12/10/2017(UTC) Posts: 96  Thanks: 13 times Was thanked: 15 time(s) in 13 post(s)
Take a look at the manual and the Shortcut Reference Guide. Specifically look for 'Stop Streaming'. Couple that functionality with the API, or scripting, you should be able to automate just about anything. If you don't want to delve that deeply in learning the ins and outs of vMix, take a look at the Third Party area of the forum, as there are a couple of automation tools there that might help.
 1 user thanked TuesdaysLive for this useful post.
You can add a trigger to the replay. On completion > stop streaming.
That will stop the stream whenever your replay is completer.
 2 users thanked jpadams for this useful post.
Joined: 12/1/2013(UTC) Posts: 56   Location: Ellenboro Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Can I do the same with a live stream? For example, have the stream stop 3 minutes after I put up a particular "show ending" slide.
