Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
I have 3 licencees for vmix. 2 4k and 1 Basic HD.
The Basic HD one - no matter what I do - will only stream in SD.
I cannot figure out why - - even if it's set to HD - the stream is going in SD.
The settings are the same as they are on the other setups.
But for whatever reason it won't actually stream in HD.
Any ideas on what else to check?
