Cannot get aspect ratio correct.
Joined: 8/14/2018(UTC) Posts: 6 Location: Bendigo Australia
As a VMix Newb, I am hoping that you can point me in the right direction on this. I have a Blackmagic mini 4k camera, plugged into a Decklink MiniRecorder 4K1 I seem to have everything set on the camera and vmix for 1920x1080 25p. The image looks good in vmix, but in both the full screen and the recoreded output the aspect is squashed too flat horizontally (top to bottom).
Any idea what settings I have wrong or need to check?
Check the vMix Settings under the Display tab. It should have the aspect ratio set to "Widescreen" for HD and 4K sources.
Martin vMix
