rtpMIDI use a signle USB MIDI controller with multiple vMix machines
Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I am trying to get two vMix machines to be controlled from one AKAI PC Mini USB MIDI controller I think rtpMIDI will be the solution and have it all working except activators on the host machine. See the PPT attached but essentially controller to host machine. Host machine I can use buttons to be shortcuts Remote machine I can use buttons to be shortcuts Remote machine I can setup activators Host machine I can not setup activators So essentially this is a working solution with the nice to have of the activiators to make my buttons all flashey and change color! Please use - it is good where i have one machine doing to different size scorboards and then when there is a four (cricket) it triggers the remote machine to play a string that runs on the advertising boards round the edge of the pitch as well as the sting to both the scoreboards that are the two display outputs on the main host system. https://www.tobias-erich...de/software/rtpmidi.htmlsmudge1977 attached the following image(s):  Slide1.JPG (161kb) downloaded 19 time(s). Slide2.JPG (148kb) downloaded 21 time(s).You cannot view/download attachments. Try to login or register.
