Production Clock for starting the stream/record
Joined: 4/6/2017(UTC) Posts: 16  Location: Adelaide, SA Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Hello all!
Can the start and end times of a event set up in the production clock be used as triggers for starting/stopping a stream/record?
As far as I can tell, the trigger 'OnCountdownCompleted' refers to the countdown inside a title.
I want to have a project set up that starts a stream based on the time so I wouldn't have to be present when it needs to go live. Basically when the event(Production Clock Event) starts, I would want it to trigger the stream and record to start and trigger a video to start playing. Then on the completion of the video the stream and record will stop (which I can do with triggers on the video).
I often forget to hit record at the start of a stream because I'm trying to coordinate so many things at once so being able to have it automatically record would be nice.
Cheers.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
no just record a blank video 5/10 mins long then mark out the time you want it to finish per production with an on completion instruction x
