paulsalv
#1 Posted : Wednesday, December 4, 2013 2:03:39 PM(UTC)
paulsalv
I have 2 Decklink Studio 2 and need to make 2 simultaneous Playlist, because the schedule if encavalam.
Question:
I can open 2 times the vMix and make a Playlist on each (1 playlist to the plate 1 and another Playlist for 2)
PC-Asus Saberttoth Z77 feature, 16 RAm, 512 SSD + HDD 2 TB 1 – Windows 7 64 Bits
Note: I'm using version vMix 11.0.0.62 on testing, for I need up to 3 simultaneous Playlists on the same machine if all goes well, install another Board Decklink, 3 playing MPEG2 files (1920 x 1080) with composite video output in SD (720 x 480)
I look forward to continue testing information
Egriswold
#2 Posted : Wednesday, December 4, 2013 5:09:40 PM(UTC)
Egriswold
Was thanked: 34 time(s) in 33 post(s)
have you tried http://www.weir3d.de/film/vMixScheduler
With just vMix You could build multiple projects and save them as desktop shortcuts then activate which ever is needed
thanks 1 user thanked Egriswold for this useful post.
paulsalv on 12/11/2013(UTC)
