Hi, when I open vMix after the update to 21.0.0.53 the UI stays most blue. I've already tried uninstalling and reinstalling, installing previous version, but still the same problem. I've also tried to reinstall the video driver.  Is there something else I can do? Thanks
I would try rebooting then reloading or updating video drivers. If you have multiple cards, make sure that vmix is using the powerful one -- do this in settings.
hi,
vmix has this issue if you are using it on a laptop with the lid closed.
pull up the lid and you are good to go.
cheers!
