Joined: 2/18/2018(UTC) Posts: 28  Location: Milan, Italy Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
Hi everyone, I've created some CC preset but I would like to set a shortcut in order to change the different CC preset during my productions without open the input settings. I've found the shortcuts SetCCGain, SetCCGamma, ... but in this case I have to set many different shortcuts and in case of some changes in the CC preset, I have to change 11 different shortcuts. Can anyone suggest a way to solve this little "problem"?
Thanks, Matteo
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
matteoarrigone wrote:Hi everyone, I've created some CC preset but I would like to set a shortcut in order to change the different CC preset during my productions without open the input settings. I've found the shortcuts SetCCGain, SetCCGamma, ... but in this case I have to set many different shortcuts and in case of some changes in the CC preset, I have to change 11 different shortcuts. Can anyone suggest a way to solve this little "problem"?
Thanks, Matteo Maybe this will help? https://www.vmix.com/hel...m?MultipleShortcuts.htmlOr look at the Advanced TAB on the shortcut screen
