Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi, have anyone use a DSLR with vMix, how can you avoid the screen Display? thanks
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
it should be in your camera menu, where the hdmi output settings are.
hellokitty wrote:it should be in your camera menu, where the hdmi output settings are. That's if it's possible to disable the overlays. Some you can, some you can't.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
search your camera model and 'clean hdmi out' to find if your camera can
thanks for your suggestion, I will look for those settings
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
If no clean hdmi you could shoot HD and stream in 720 giving you up to a 1.5x digital zoom to crop the overlays.
On some DSLRs, like my Canon 70D, you can't get a clean feed with stock firmware. You need to load third party firmware, like Magic Lantern, to make this possible. Also, some DSLRs don't like to run continuously. They may overheat.
