pagu
#1 Posted : Saturday, July 21, 2018 6:40:45 PM(UTC)
pagu
Hello everyone, I need some info about Facebook live event.
I add input camera by Avermedia pro 2 plus capture, My camera it’s a Sony 4K ax53.
When I record in 4K (In camera) i want stream the video, but I need info about resolution when I add the camera.
If the output resolution of camera it’s 4k 25p which resolution I have to choose?
I can select 720p as live event of Facebook? I don’t understand which resolution set when I add the camera for a best quality live event.
Thank you everyone.
#2 Posted : Sunday, July 22, 2018 11:25:59 AM(UTC)
Hi
first check facebook recommended settings for live streaming : https://www.facebook.com...6955?helpref=faq_content
As you can see this a FAQ > Frequently Asked Question
Regarding your production workflow, you have several options. It's been discussed frequently on this forum too.
It mostly depends on your gear possibilities:
- can your cam record 4K internally AND output another resolution?
- what are the input resolution supported by your capture card?
- what do you want to do in vMix apart from streaming?
- what resolutions do your other project inputs support? (screencaptures, graphics, media, etc...)
- etc...
If you go step by step, you will find the best solution for you. There is no magic recipe valid for everyone or every project. It's a matter of knowing and understanding what you deal with and want to do with your specific equipments
Guillaume
pagu on 7/28/2018(UTC)
pagu
#3 Posted : Saturday, July 28, 2018 4:11:58 AM(UTC)
pagu
Hello Dwam,
Thnak you for your reply, yes i found an good point.
My camera can record in 4k but on same time not able to output on this resolution.
I need to stream on 720p facebook or 1080p on youtube, but i see that it's possible choose the defoult preset stream options by vmix that i think are been optimized for facebook and youtube standards, well?
my problem is that i want stream on this resolution and record in 4k for post editing.
have you some idea? i think it's only a possibility: record and stream mp4 by vmix, well?
Thank you Dwam,
sorry for my english.
