Feature Requests
Data Sources Feature Requests
Hello Only "Column" lookup in vmix .Very inconvenient when entering data . hope to open the "row" lookup.
Can you elaborate on this a bit more please ?
 Only "Column1 2 3....." Unable to accurately locate the specified data in a table
if you "convert rows to collumns" you can access "specific cells" as it were Quote:Convert rows to columns: Ticking this box will group all rows in the data source into a single row, numbering the column names in the process. For example a spreadsheet with Name and Description and 3 rows will become Name1, Description1, Name2, Description2, Name3, Description3 with all data contained in a single row.
if the source is an xml one can filter with xpath specifics
This requires a lot of preparatory work, and it's not easy to use other functions of the spreadsheet. If I need to use the computing function or sort of the spreadsheet, I can quickly apply the data to the XAML. Can you understand ? Thank
not knowing the exact goal but trying to use the computing function or sort of the spreadsheet wouldn't that mean exacty doing that within your spreadsheet in the first place? even create a second sheet based on your criteria to use in datasources containing the desired data ?
on the other hand preparatory work can never be enough and is key to a production
Feature Requests
