spencerm24
#1 Posted : Sunday, June 24, 2018 1:25:33 AM(UTC)
spencerm24
Rank:: Advanced Member
In an attempt to offload some of the load from my main production PC, looking at this PC, as the streamer and recorder. I'd use one single NDI input from the main PC to this one.
Will this do the trick? It seems to me to meet the specs of this basic requirement. Before I take the plunge, any thoughts?
https://www.dell.com/en-...esktop/di3670_btsb_s411e
#2 Posted : Sunday, June 24, 2018 10:24:59 AM(UTC)
Was thanked: 795 time(s) in 589 post(s)
Why don't you just upgrade your PC with a better CPU/RAM/GPU ?
Otherwise as long as you use a decent PC (i5 or i7) with an nVidia GTX card it should be fine. This DELL is more than enough btw
spencerm24
#3 Posted : Sunday, June 24, 2018 2:59:23 PM(UTC)
spencerm24
The Main PC has an i7 8700k, 16GB ram, and a GTX 1060 graphics card. It runs about 40%-50% normally, but when I try to cue up a replay, it spikes to over 100% and starts dropping frames, so I want to offload some of the streaming/recording workload to a secondary streaming PC, unless theres something I can do to help the main PC.
