vMix'AMCP Scripting Question
Joined: 2/18/2018(UTC) Posts: 39  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Hi Folks,
I'm pretty new to VB.Net, and I'm trying to figure out if anyone has worked out how to send AMCP commands from vMix. Specifically, I'm trying to send AMCP commands to another PC running CasparCG.
vMix is fantastic, and I'd love to keep everything in the one system, however I need to playback a video with a separate alpha channel. A Quicktime file with Alpha just chews up resources, a PNG Stinger takes over 10 minutes to ingest (and loses sync with the audio over time), so CasparCG is the best way to spread the resource load out for this particular scenario.
If anyone has worked out how to send AMCP commands, or can point me in the right direction, I would greatly appreciate it!
Cheers all!
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
That would be awesome!
Make this a feature request! Something similar to the NewBlueFX connectivity, where Animation and data can be controlled from within Vmix.
