davesuemcbride
#1 Posted : 11 years ago
davesuemcbride
Hi All,
Anyone had success using an Ubiquiti airCam IP camera with vMix over RTSP?
Basically, looking for something architecturally like a Cube, but cheaper and more integrated for a dicey location.
Thanks,
David McBride
davesuemcbride
#2 Posted : 11 years ago
davesuemcbride
Just for anyone searching someday, went ahead and bought the Ubiquiti airCam - what the hey it's <$100 ;)
Was easy to connect to vMix - basically the entire setup worked on first try no surprises. It is 720 max, seemed to keep an honest 30 frames, didn't have a noticeable artifacts at its max 5mb rate, and had good color, but did look a bit soft in the lens. For an exposed remote usage it'd be a good fit, especially if you're already using Ubiquiti products.
