mkrigsman
#1 Posted : Wednesday, June 13, 2018 7:44:58 PM(UTC)
mkrigsman
I am bringing an external USB source into vMix to link with HDMI video from a Magewell capture card. Using the Multiview method I cannot use multicorder, which I do need.
As the workaround, I am using the legacy Magewell method, to marry the external USB audio with the HDMI input. I realize this is not the "right" way to create the link between the video and audio sources. However, it works fine and it allows me to use multicorder.
Can anyone see a problem using the legacy mode in vMix for the Magewell audio or will I encounter unexpected issues later?
