apell
#1 Posted : Wednesday, June 6, 2018 8:53:36 AM(UTC)
apell
You have been a member since:: 4/21/2015(UTC)
[img][/img][img][/img]Every time i upload inside with overlay a picture is very slow to ascend or never goes up.
(image up)[img][/img]
apell attached the following image(s):
VMIX TEAM.jpg (147kb) downloaded 4 time(s).
stuartdeankites
#2 Posted : Wednesday, June 6, 2018 9:17:32 AM(UTC)
stuartdeankites
What are your overlay settings for overlay 1? this might be the issue. Click on the overlay button (bottom right of the screen to check them)
Joeboe
#3 Posted : Wednesday, June 6, 2018 9:42:36 AM(UTC)
Joeboe
I think I see his problem....he has to key out that green first, and maybe make a virtual input of that, then he will be able to use the virtual input to overlay his image, or go to the Overlay 1 settings, and make the image to be overlayed to be infront, then resize to fit the green area...
