3rd Party Software and Development
Playlist with external API trigger between clips
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
I have a playlist (loop) with 10 cuts.
Between each cut, I'd like to hit an external web URL (to our media server API to tell it to do something).
Any way to do this?
I would think using sendkeys and AHK would work (set a keystroke to open a url).
Joined: 2/7/2018(UTC) Posts: 45 Location: Saint Louis
Thanks: 4 times Was thanked: 4 time(s) in 3 post(s)
Did you get that to work RoverRadio? Is it possible to program a trigger or api command to send a shift+arrow keystroke combo to another app window (not vMix) if so, I could advance a timeline in my graphics tool to display the next item in a list that matches the content in the clip playlist.
