douglashoover
#1 Posted : Wednesday, November 27, 2013 2:46:17 AM(UTC)
douglashoover
The cameras are the JVC GZ-E505 Full HD Everio Camcorder #GZ-E505B with HDMI ports
These are the ports I have on my Macbook Pro (don't know what they are) http://screencast.com/t/UhBstnKQKR thunderbolt? or firewire?
I bought the Basic HD http://screencast.com/t/R9niDk0szn6
OSX
Version 10.8.4
processor 2.66 GHZ Intel core 17
memory 4GB 1067mb DDR3
Intel HD Graphics 288 MB
#2 Posted : Wednesday, November 27, 2013 7:07:57 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
Hi Douglas,
Looks like you have one thunderbolt or display port available.
If it is thunderbolt it will have a lightning symbol next to it.
If so what you will need is a Thunderbolt Enclosure along with a suitable card to install in it.
There are a couple of options on our supported hardware page:
http://www.vmix.com.au/supported-hardware.aspx
We mainly use a combination of the Magma ExpressBox enclosure and the ViewCast 845e with its 4 SDI inputs.
For two HDMI inputs, the following card could be used:
http://www.magewell.com/...ni_features.html?lang=en
