Can't update an image in a title
Joined: 11/21/2013(UTC) Posts: 32 Location: Stockholm
Thanks: 2 times Was thanked: 5 time(s) in 5 post(s)
I try to update an image in a title that i made thru the web API. I can update the text easy but when I try to update the image by sending this command http://127.0.0.1:8088/API/?Function=SetImage&Input=1&SelectedName=Bild&Value="file:///C:/Program Files (x86)/vMix/titles/pinkturbo.jpg" I get Invalid image format reply. What am I doing wrong?
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
http://127.0.0.1:8088/API/?Function=SetImage&Input=1&SelectedName=Bild&Value=C:/Program Files (x86)/vMix/titles/pinkturbo.jpg no quotes if only one image is in the title it appears you dont even have to specify the SelectedName
Thank you so much doggy!! Just a little note to myself: This command changes the background image: http://127.0.0.1:8088/API/?Function=SetImage&Input=1&Value=C:/Program Files (x86)/vMix/titles/xxx.jpg And this command changes the second picture http://127.0.0.1:8088/API/?Function=SetImage&Input=1&SelectedName=Image1&Value=C:/Program Files (x86)/vMix/titles/xxx.jpg
 1 user thanked tubbis_2 for this useful post.
