ODYSiE
#1 Posted : Sunday, November 17, 2013 4:08:20 PM(UTC)
ODYSiE
Total noob here so please forgive if this is a simple question. How do I include Sound Spectrum's G Force visualizer as an input? Thanks!
TVIason
#2 Posted : Thursday, November 21, 2013 5:34:19 AM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
Can't you use desktop capture?
ODYSiE
#3 Posted : Thursday, November 21, 2013 3:27:46 PM(UTC)
ODYSiE
I'm running G Force on the same computer with vMix. How would I set that up as desktop capture links to another computer?
tesn
#4 Posted : Friday, November 22, 2013 9:26:29 AM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
Desktop capture can be used on the same machine as vMix.
I don't know what your visualizer is, but I suspect you may need multiple monitors. Put the visualizer on one, and have Desktop Capture use that.
I believe you can put in //localhost or localhost as the desktop capture ip address. I was going to complain that desktop capture uses the ip address only, and if you're always using the machine that vMix is on, you don't want the ip address to keep changing. So I tried localhost, and I'm pretty sure it worked.
-Brian
