gabriele
#1 Posted : Friday, November 15, 2013 12:04:13 PM(UTC)
gabriele
salve volevo sapere voglio usare vmix e gestire un solo ingresso video ed usare i titoli di vmix e possibile usare un unica scheda intensity pro black magic
vmixsupport
#2 Posted : Friday, November 15, 2013 6:49:53 PM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
If you are planning to only use one camera input into your computer with vMix, then yes the one capture card is fine as you have suggested such as the Intensity Pro.
