amsudeen
#1 Posted : Thursday, November 14, 2013 7:23:10 AM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
when play list file, first file not stop exactly. second file also play some frames.
#2 Posted : Thursday, November 14, 2013 9:16:45 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Untick "Automatically Play Next Item" if you do not want the second file to play during the stinger.
Also, QuickTime MOV files are not frame accurate (quicktime limitation) so they will not play for exactly 3 seconds,
you will need to create an Image Sequence for frame accurate stingers.
amsudeen
#3 Posted : Thursday, November 14, 2013 9:29:15 AM(UTC)
amsudeen
how can add Image Sequence in list file.
same time we are created 600+ QuickTime MOV files. using in transition fx.
we want load all in one list. give me solution.
thanku
