nimh
#1 Posted : Wednesday, November 13, 2013 6:27:49 AM(UTC)
nimh
Am I missing a setting, or is there no audio being pulled from rtmp url inputs? I am not having any trouble grabbing the video of an rtmp url as an input, but no audio meter shows up to the right of the input. I also noticed that the audio settings box does not function when clicked on. Is this a known limitation of vmix at the moment?
#2 Posted : Wednesday, November 13, 2013 11:23:57 AM(UTC)
RTMP uses the Adobe Flash player for playback.
This means it is compatible with the vast majority of streams, the downside is there is no audio meter or advanced audio settings available.
Audio should still work fine though and you can control mute/volume from the mixer.
