Alfredvdh
#1 Posted : Thursday, November 7, 2013 4:08:42 PM(UTC)
Alfredvdh
I'm new her in the forum and as user of Vmix.
Normaliter i'm using VidBlaster, but starting with a new project i'm now using Vmix.
It is used for a live television program.
But i have a small issue.
When i'm starting a movie (.mov container), it takes a second or a half second, when it starts to play. So, the first time i'm seeing only a freeze frame, and then after a second, it start playing.
How can i avoid this, en let the movie start immediately after cutting.
Hope you can help me.
Alfred
Egriswold
#2 Posted : Thursday, November 7, 2013 9:35:14 PM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
Alfred, not all mov files are made equal. It usually comes down to codec. If you want a windows machine to play video smoothly then avoid mov files. especially if they came directly from a MAC. Your just asking for trouble. convert them to a WMV, MPG or AVI file. Even MAC's can output other file formats if you push the operator hard enough.
