spencerm24
#1 Posted : Wednesday, May 30, 2018 9:52:17 AM(UTC)
spencerm24
I have seen this in some other Live Stream programs, as well as graphics programs. I'd love the ability to build a show on one computer, and package it up to a single file (yes, this file will be large, I'm aware of that) to bring to the main production PC. Including all shortcuts, videos, images, titles with proper links to images.
Currently the only way I've found to do this is to mimic the same file structure on the build PC (for example, if an image is on D:/Documents/vmix images I make sure the same path is on the production PC) This is very tedious and one mistake can cripple a production that was built on another PC.
The thinking behind this is not having to set up the production PC every time you want to make a show, you can do it on a laptop or something similar, and transfer it to the production PC.
TuesdaysLive
#2 Posted : Wednesday, May 30, 2018 10:44:51 AM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
+1
Vuurmannetje
#3 Posted : Wednesday, May 30, 2018 11:24:15 AM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
+1 here!
I personally use quite large (over 200 input) files with lots of smaller assets, so being able to package them for my backup server would be great. Currently we use a cloud folder for the assets which works I guess, but still need identical file structure.
HDLabs
#4 Posted : Monday, October 5, 2020 12:49:58 PM(UTC)
HDLabs
Same issue. No answer in two years?
vmixgreg
#5 Posted : Tuesday, October 6, 2020 11:41:37 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Hi HDLabs,
Please review the following Knowledge Base article:
https://www.vmix.com/kno...ttings-between-computers
vMixGreg
