Argo82
#1 Posted : Monday, May 21, 2018 11:18:21 PM(UTC)
Argo82
Was thanked: 7 time(s) in 5 post(s)
Hi Everyone,
As this is more hardware related, I thought I re-ask here instead of the general section.
Has anyone every tried using an LED back lit gaming keyboard with vMix and activators? I've recently seen some keyboards with advanced control over the lighting that can control the lighting on specific keys. I don't know if this is done using midi or some other tech. Would this be compatible with activators or maybe something to look at in the future? With clear re-legendable keys this would be another great control option.
hellokitty
#2 Posted : Wednesday, June 6, 2018 2:44:12 PM(UTC)
hellokitty
get a corsair K95 Platinum,https://www.corsair.com/us/en/Color/Keyboard-Model/Key-Switches/Keyboard-Layout/k95-rgb-platinum-config-na/p/CH-9127012-NA\
with the corsair icue software you can change and reprogram everything and it has 6 extra keys for whatever you want. you can download pre-made templates also. it is pricey but worth it. excelent warranty and they are just solid.
