#1 Posted : Friday, May 18, 2018 8:55:38 AM(UTC)
Having a bit of trouble syncing audio on a delayed second recording.
first recording is output1
second recording is a NDI input of output1 that is delayed so far so good be it the audio is now out of sync by de delay time. delaying the audio source in recording setting works be it now the clip has no audio at the start and frozen video at end of recorded clip.
any way to have the NDI input of vMix output1 maintain the audio in sync in the first place ? (delaying both video and audio as one input to be recorded )
thank you
#2 Posted : Saturday, May 19, 2018 4:03:13 PM(UTC)
solved !
TuesdaysLive
#3 Posted : Saturday, May 19, 2018 8:11:35 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
Care to share how you solved the issue?
thanks 1 user thanked TuesdaysLive for this useful post.
Ario on 5/21/2018(UTC)
#4 Posted : Friday, May 25, 2018 1:58:56 PM(UTC)
what i did :
- completely turned of the build in laptop mic !!!! (is what basically gave me the initial headache)
General settings of outputs/NDI:
- output1 as output with ndi activated
- output2 set to the delayed input
Input settings ( NDI of vMix output1 ):
- delay in advanced tab
- delay in audio settings
- set its audio to busA for example
recording:
- 1 as regular recording of regular output1
- 2 of output2 with audio set to busA
During recording audio has to be on of both outputs !
