dasmedienatelier
#1 Posted : Monday, May 7, 2018 6:12:10 AM(UTC)
dasmedienatelier
It would be great to be able to select the camera angle which text should be changed/set.
We are broadcasting American Football and usually have our main camera set to input 2. We are using a XKeys controller and programmed 4 buttons to set the ReplayEventText to „1st“, „2nd“, „3rd“ and „4th“. This way our replay personnel can immediately set the text for the event without having to use a mouse. After the game we use this information to export a play-by-play which mainly uses (exports) events of our main camera (#2). But since the event text is only exported if the camera angle is used, the eventtext of our camera 1 don’t get exported.
