hrvboy
#1 Posted : Wednesday, May 2, 2018 8:40:56 PM(UTC)
hrvboy
This is not a new feature as much as a slight fix to an existing one.
Currently, I am using an XML as a data source. I use an OnTransitionOut trigger of the Instant Replay to go to the next row in the table(via DataSourceNextRow) to change a title text. It works great until I reach the last row.
What would be nice to have happen is that if the "Loop" is turned on in the Data Source Management screen that once it reached the last row, DataSourceNextRow would then go to the first row.
Hope this makes sense.
richardgatarski
#2 Posted : Thursday, May 3, 2018 8:43:12 AM(UTC)
richardgatarski
Hi hrvboy and welcome to the forum!
It will be much easier for us to track things, evaluate, and eventually vote if you give your request a proper Topic name (you can edit it).
And, as the developers say, also explain use cases and how the feature might be implemented.
Guest (4)
